Garbage Disposal Knockout Plug - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2009, 01:07 PM   #1
Garbage disposal knockout plug
This seems like a really dumb question... but I'm prepping to install a new dishwasher, and all instructions I have read on the web say to knock out the disposal plug before installing it so it can be removed from the top of the disposal. Our disposer is already installed... do I have to remove it, or will I be able to fish it out from the sink?
jdhar is offline   Reply With Quote
Old 12-13-2009, 03:35 PM   #2
You should remove it. It's just plastic, so it will probably eventually get ground up, but you don't want to damage your new disposal.
Here's a way to get it out without removing the disposal: (First, unplug the disposal or kill the circuit breaker). If you have any plumber's putty or sonething sticky like that hanging around (playdough? wax? double-sided tape?) put a little ball on the end of a screwdriver and carefully reach it down there and "stick" the plug and lift it out.
Ishmael is offline   Reply With Quote
Old 12-15-2009, 08:52 AM   #3
Do you have a long pair of thongs they use for cooking and a small flashlight??
That will do the trick I have used them several times on stuff accidental put down there that won't grind up.
SULTINI is offline   Reply With Quote
Old 12-15-2009, 11:29 AM   #4
Chicago, IL
Michael Thomas's Avatar
Stuff the dry food waster grinder with a continuous length of paper towling to just below the level on the inlet, knock out the plug, retrieve it form the top of the paper, then fish out the paper.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 12-15-2009, 05:53 PM   #5
firehawkmph's Avatar
Rewards Points: 1,824
Take a screwdriver, knock the plug in, suck it out with your shop vac. And if you don't have a shop vac, you should.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-20-2009, 04:29 PM   #6
Rewards Points: 150
rudolph58
In IL. plbg.code it is illegal to use the garbage disp.as the discharge for your dishwasher.a dishwasher branch drain tube nust be used.
rudolph58 is offline   Reply With Quote
Garbage Disposal in the country? OffRoadAudio Plumbing 6 09-01-2009 05:19 PM
SImple Simple Dishwasher and Garbage Disposal Connection tabasco Electrical 2 08-06-2009 11:13 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 11:03 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 07:35 PM
