Old 01-28-2006, 01:06 PM   #1
Ron
Garbage Disposal on a "Grey-Water" line?
I live in a rural area and have a septic line and a seperate "grey-water" line. Of course, my kitchen is on the grey-water line. I would like to install a garbage disposal, but have been told not to. Any thoughts on this?
Ron is offline   Reply With Quote
Old 01-31-2006, 08:00 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A garbage disposal puts a lot of solids out, and isn't recommended for any septic system. It definitely should not be put on a grey water line.
You're just asking for septic clogging problems.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-01-2006, 09:43 AM   #3
Contractor
Ron, have you considered a compost bin? You can recycle vegetable waste back into your property. Meat, grease and oils should never go into any septic system including municipal.
Teetorbilt is offline   Reply With Quote
Old 02-04-2006, 08:43 PM   #4
Ron
Sorry, I guess I didn't make myself clear the first time. The "grey-water" line is seperate from the septic line and never enters the septic tank or field. The grey-water just runs out into a field ajoining my property. That's why I thought it would be safe to run a garbage disposal on the line.
Old 02-05-2006, 12:17 PM   #5
Long-Time DIYer
Discharging "grey water" - or anything else outside of a single or separate septic system - onto the surface or into a drainage ditch, etc. is illegal in most places. (Check with your local Health Department, which is the usual permitting agency, for verification.)
If you get caught with an illegal waste water discharge, or ever try to sell your property and it's inspected then, you'll probably have to correct it.
Your call.
Good luck!
Mike
Old 02-05-2006, 12:44 PM   #6
Ron
Thanks for the info. Mike. I didn't know that about grey-water lines. Nobody mentioned it, when we bought the house in '93 and now I'm afraid to mention it. In fact the owner showed us where the line came out and said how much better it was that the grey water didn't go into the septic, etc.. I guess you live and learn. Thanks again
Old 02-05-2006, 11:39 PM   #7
Long-Time DIYer
A properly designed and built septic system should be able to handle all grey water and all else just fine.
We've been on a septic system since 1977, and I have the tank pumped every 5 years as the state recommends. All of our home waste water goes into it, and we've never had any problems. If you do, you usually can correct it by just adding another drainfield line.
We don't have a disposal, though. We either put it out for the birds, neighborhood dog friends, or overboard for the fish and turtles, depending upon what it is (never any bones or grease though...that all goes in the trash).
Good luck!
Mike
Old 02-06-2006, 12:21 AM   #8
Contractor
Mike, got catfish? I have some funny stories.
Old 02-06-2006, 09:25 PM   #9
Long-Time DIYer
I don't care WHAT the rich people say about cavier, salmon, sturgeon,etc., there aint NOTHING better than FRIED CATFISH FILETS!
Trotline and fry 'em up in a skillet over a fire, Miracle Whip, bread, pickles, and a few beers, give me a hammock and I'm a happy goner. LOL.
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
HELP I need to wire a switch to an outlet to hook up my garbage disposal r8drman69 Electrical 8 06-05-2007 11:18 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
DIY Garbage Disposal replacement bigbob Plumbing 1 06-07-2006 07:05 PM
