#1 |
Next Time...New Build
Garbage Disposal Drains
I have a double sink, one side with a disposal on it. Is there some sort of check valve that can go on the other drain to prevent backflow into the other side when the disposal is run?
It doesn't always happen, but if the disposal is full and there is water building up in the sink, when you run the disposal some of the discharge will go into the other sink. I've tried plugging the other side but it doesn't always work and seems like a hassle. Thanks in advance |
#2 | |
Garbage Disposal DrainsQuote:
It is not usual or customary to put check valves in the drain pipe as you described.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 04-27-2010 at 05:49 PM. |
#3 |
Super Moderator
Can you post a picture of the piping?
Is there a P-trap for the disposer and another one for the sink? If they are piped together and then into a single P trap---that might be the problem--Mike-- |
#4 | |
Seems to me what is happening is that when the disposal is run, it shoots the discharge past the T and up the other side. I will attempt to post a pic. Thanks for the replies. |
#5 |
Super Moderator
That's the problem. They are piped together,the disposer is pushing the sewage back up the other sink.
See if a T or Y can be installed at the main drain at the back of the cabinet.--Mike-- |
| Display Modes | |
| SImple Simple Dishwasher and Garbage Disposal Connection | tabasco | Electrical | 2 | 08-06-2009 11:13 PM |
| Old garbage disposal question please help. | linuxguy0481 | Kitchen & Bath Remodeling | 3 | 07-26-2009 11:03 PM |
| Garbage Disposal | howard.wheaton | Electrical | 7 | 05-10-2009 07:36 AM |
| slow draining garbage disposal | lchiu7 | Plumbing | 3 | 04-05-2009 04:00 PM |
| garbage disposal and dishwasher power | amakarevic | Electrical | 11 | 10-06-2008 07:35 PM |
