Garbage Disposal Clogged - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2009, 10:56 AM   #1
Rewards Points: 1,062
Question
garbage disposal clogged
my garbage disposal is clogged, the water drains very slowly and it regurgitates water after it is turned off. i bet these are fairly common symptoms. do i need to take it apart and clean it inside (yuck) or can it just be plunged ?
thanks.
Old 03-31-2009, 02:16 PM   #2
Rewards Points: 1,418
You will need to disconnect the outlet pipe down under the sink, and clean things out from there. You should not have to reach very far inside the disposer from there. The drain and trap may need cleaning too.
You can try plunging it but I suggest pushing down to drive solid matter further down the drain rather than pulling up and sucking debris up into the disposer under the rotor.
Garbage Disposal Dilemma (with pic) tommy potatoes Plumbing 13 03-23-2009 06:50 PM
replacing a gfci recetacle for a dishwasher and garbage disposal sarahzuno Electrical 12 01-21-2009 12:41 AM
GFCI and garbage disposal Jeremy Hillary Boob, PhD Electrical 2 11-28-2008 08:01 PM
Replacement Garbage Disposal lvrollers Plumbing 9 10-11-2008 09:50 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 07:35 PM
