Garbage Disposal, Which Bowl? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2010, 11:07 AM   #1
garbage disposal, which bowl?
i have a double bowl sink in my kitchen, one large, one small. all things being equal, which bowl should i install garbage disposal on? what is the common practice?
thanks.
ninghai is offline   Reply With Quote
Old 01-24-2010, 11:48 AM   #2
Rewards Points: 346
The one that is empty most of the time. My wife loves to put stuff in the bowl with the disposer making it entirely useless.
Rege
RegeSullivan is offline   Reply With Quote
Old 01-24-2010, 02:44 PM   #3
Household Handyman
Rewards Points: 1,408
This will depend on which side the drain is on, meaning the main drain for both sinks. I have not seen a disposal yet that allows for another sink to tie into it. The disposal should tie into the drain of the other sink which probably leads to the main drain for both sinks. UNLESS, you have a system which has the drain in the middle, I have seen a few of these, then it may not matter depending on IF you have room for the disposal and plumbing. OR, IF, you have one of those systems in which the sinks are tied together and the main drain is off-set to one side of the sinks, then the unit would go to the sink furthermost from the main drain. Good Luck, David
Old 01-24-2010, 06:24 PM   #4
firehawkmph's Avatar
Rewards Points: 1,822
Ning,
Just my own .02. I normally put the disposal in the small bowl of a two-bowled sink. Only for the reason that you will be handwashing dishes in the large bowl and it never fails there are always a couple more pots or dishes to rinse the heavy stuff off of after you already filled the large bowl with soapy water.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-24-2010, 08:50 PM   #5
Rewards Points: 1,442
The outlet of a disposer can be routed into the main drain with no more difficulty compared with a straight sink drain. The only reason for having to re-route the drain pipes is if the body of the disposer was in the way.
Old 01-25-2010, 05:31 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Originally Posted by firehawkmph View Post
Ning,
Mike Hawkins
There you have your answer Also ,if it is anything like mine ,you need to have the large sink empty of water before running the machine as it is vented through the large drain, at least that is what the plumber told me.
Old 01-25-2010, 09:10 PM   #7
Learning by Doing
Leah Frances's Avatar
One of my DH's dreams (especially now that we're watching a blu-ray on his new 60 inch plasma - satisfying his previous wish) is for a garbage disposal in both bowls.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-26-2010, 05:15 AM   #8
chrisn's Avatar
Rewards Points: 228
Why?
Old 01-26-2010, 12:45 PM   #9
Learning by Doing
Simple. "Why not".
Old 01-26-2010, 01:43 PM   #10
Rewards Points: 150
i generally put the GB on the DW side of sink
rudolph58 is offline   Reply With Quote
Garbage Disposal in the country? OffRoadAudio Plumbing 6 09-01-2009 05:19 PM
SImple Simple Dishwasher and Garbage Disposal Connection tabasco Electrical 2 08-06-2009 11:13 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 11:03 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 07:35 PM
