Old 11-05-2012, 09:50 PM   #1
Garage utility sink installation (repost)
When my house was built last year I asked the builders to put all the plumbing in the garage for the eventual installation of a sink. The hot/cold and drain is all there.
See the picture :
http://www.devbeva.com/garage.jpg
I assume this should be an easy install but having never done this before - I am not sure how to hook up to the drain ?
Can anyone help ?
drinkwater is offline   Reply With Quote
Old 11-06-2012, 05:24 AM   #2
Super Moderator
That's not right for a sink drain----no vent----
If an AAV is allowed in your area--(air admittance valve)--use one to vent that----
T--top of pipe---trap adapter to the sink( P -trap at the sink drain)----length of pipe higher than the sink top--then the AAV
Hanh the sink so we can see exactly what you need.
Garage utility sink installation drinkwater Plumbing 1 11-05-2012 09:44 PM
Bar Sink and Utility Sink Drain Line - T or Wye mykayel Plumbing 7 01-12-2011 10:34 PM
utility sink installation jmormando Plumbing 1 11-29-2010 04:59 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 09:10 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
