Garage Drain With No Trap; How To Unclog - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2012, 11:16 PM   #1
Garage Drain with no trap; how to unclog
So my builder did me a favor of giving me a garage drain without a trap or cleanout. Not only that, he gave me two entries into the drain. Think of it like a goal post. Two entries about 10 feet apart and I assume they combine into one pipe and it goes out to the storm drain.
The clog seems to be in the pipe going to the storm drain. If I try to snake it, the snake just comes up from the other entry. I can't get the snake to go down into the 'storm drain'.
I have put a bottle of draino into the drain and tried to plunger on one side but everything just comes up to the other side. What is the best way to stop up the other entry to try to get the air pressure down into the storm drain?
Thanks!
Scottcey is offline   Reply With Quote
Old 11-11-2012, 07:37 AM   #2
I assume you have tried snaking from both drains?? There has to be a Tee, but if it not a directional Tee, it will be hard to snake. Chemicals might work, depending on the what the blockage is, but if it doesn't work, you have to deal with the chemicals somehow. Maybe a video snake is the answer.
Old 11-11-2012, 08:14 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Thanks!
Ayuh,... Find a rubber expansion plug that fits it, 'n tighten it in...
Then work from the other drain hole...
Old 11-11-2012, 02:43 PM   #4
Bondo, Thanks for the heads up on the rubber expansion plug. I got one and was able to move some junk in the drain by plunging time and time again. Its still not clear, but, I think if I keep doing this, it will over time.
Just Bill, yeah, the snake just goes from one end to the other and I cant get anything to bend down into the main drain. I might try air soon because I don't think the chemicals will break up the road grime in the drain.
But at least I got some movement with the plug and plunger.
Thanks!
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
How to unclog condensation drain pipe in attic rpguy4 HVAC 6 06-05-2010 02:07 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
