Garage Drain - Help Needed - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2007, 07:15 PM   #1
Garage Drain - help needed
I cannot find a replacement drain for my garage. The opening is 8 3/4" and would require a steel or cast iron drain. The old drain was rusted and caved in. I found an 8" drain at Home Depot - but it measures 10 1/4" in diameter. I believe I need a 7" drain with legs to sit in the piping. Any ideas. I checked the website of the company Plumbest and all the had was 6(8"dia) and 8(10 1/4") diameter drains. Any websites or suggestions on where to find one before I call a plumber?
Paul - Cleveland Ohio
brudah is offline   Reply With Quote
Old 04-15-2007, 07:25 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
How about posting a picture.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-15-2007, 07:46 PM   #3
It is the perforated sewer strainer second item down - I just cant find one with an 8 3/4" diameter to fit
Old 04-15-2007, 07:49 PM   #4
Journeyman Plumber
Maybe you can order it over the net, or if there is a local plubing supply house there, try them.
Old 04-15-2007, 10:27 PM   #5
If your in a pinch and can't find one go to a welding shop and have them make one up for you ,just give them size and have them drill out as many hole as needed .
tzzzz216 is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
Rheem RXCH-A14 drain pan needed johnd393 HVAC 10 05-14-2007 12:58 PM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 05:38 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
