-   -   Garage Drain - help needed (http://www.diychatroom.com/f7/garage-drain-help-needed-7812/)
brudah 04-15-2007 07:15 PM
I cannot find a replacement drain for my garage. The opening is 8 3/4" and would require a steel or cast iron drain. The old drain was rusted and caved in. I found an 8" drain at Home Depot - but it measures 10 1/4" in diameter. I believe I need a 7" drain with legs to sit in the piping. Any ideas. I checked the website of the company Plumbest and all the had was 6(8"dia) and 8(10 1/4") diameter drains. Any websites or suggestions on where to find one before I call a plumber?
Paul - Cleveland Ohio
Ron The Plumber 04-15-2007 07:25 PM
How about posting a picture.
brudah 04-15-2007 07:46 PM
http://www.plumbest.com/dmdocuments/f44.jpgIt is the perforated sewer strainer second item down - I just cant find one with an 8 3/4" diameter to fit
Ron The Plumber 04-15-2007 07:49 PM
Maybe you can order it over the net, or if there is a local plubing supply house there, try them.
tzzzz216 04-15-2007 10:27 PM
If your in a pinch and can't find one go to a welding shop and have them make one up for you ,just give them size and have them drill out as many hole as needed .
