Galvanized Vs Flexpipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2009, 08:55 AM   #1
galvanized vs flexpipe
I am having a new gas furnace installed. I have had both galvanized steel and flex piping recommended for the job. This is a very short line going from the gas meter then about ten feet outside and into the house. I also have gas logs which are running in copper and will need to be replaced. I have been discouraged from using black iron because of rusting outside. Any ideas on pros and cons of galvanized vs flex for gas?
beatrice5 is offline   Reply With Quote
Old 04-21-2009, 11:00 AM   #2
HVAC / Plumbing
Trac pipe is good if installed correctly . Grounded , correct fittings , etc, very thin walled.. I would choose black pipe because of thickness.. Sch. 40.. No galv.pipe for me
kenmac is offline   Reply With Quote
Old 04-21-2009, 11:50 AM   #3
Remodeling Contractor
Gas needs black pipe, galvanized is illegal to use. If you are concerned about it rusting outside, coat it or run it inside a PVC sleeve and caulk all joints.
Old 04-21-2009, 01:58 PM   #4
Galvanized problems?
Several local contractors recommended galvanized and several flex. I was told the flex might not be a great idea if there's any risk of it getting bumped outside and to go with the galvanized. What is the problem with the galvanized? The black iron seems to rust -- I already have some going to a generator which rusted in a couple of years....
Old 04-21-2009, 02:19 PM   #5
BIGRED
Rewards Points: 252
It sounds like you have an appearance issue. If it is just a matter of appearance do as Mr. Bob suggested. I have not heard of a legality issue, but galvanized has been the standard for years for potable water and black has been labeled for most other processed gasses and/or liquids. Flexi pipe (Normac etc.) is being marginally accepted by different states for outdoor use with many restrictions. It can be punctured easily with concrete breakers, it can be hooked and ripped apart with back hoes and skidsteers. I even accidently put a sharp square edge shovel through a piece of 3/4. Black pipe for gas is by far the safest -and cheapest- way to go. Get yourself a can of your favorite irredescent Pink spray paint and spray paint that nasty old black pipe to suit.
Grampa Bud is offline   Reply With Quote
Old 04-21-2009, 11:39 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Galvanized pipe is generally not used for gas piping due to the possibility of the pipe flaking and causing obstructions in the orifices leading to equipment failure. Black iron is much better suited for gas installations. Like anything left to the elements and untreated, black iron WILL rust. Its nature....just as wood siding will deteriorate, cars will rust, decks will fade...if nothing is done to protect them. CCST is generally an accepted material for gas piping also. However, due black irons strength and rigidity, I would use it for an outdoor application and paint it whatever color suits your fancy. If it is going to be buried, there is a plastic tape wrap that goes on the pipe to protect it.
JDC is offline   Reply With Quote
Old 04-22-2009, 08:27 AM   #7
Black
Black pipe, flex connector's close to equipment.
SULTINI is offline   Reply With Quote
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 12:40 PM
Old Galvanized shower/bath inlets Relpace Pex? sssalas Plumbing 2 09-08-2008 04:56 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 01:22 AM
Galvanized Flashing with ACQ Treated Lumber? Ler0y Jenkins General DIY Discussions 5 05-18-2008 11:59 AM
