Galvanized Steel Plumbing Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2012, 05:20 PM   #1
Galvanized steel plumbing help
Hello. I have been remodeling a house and have ran into a plumbing problem. All of the drain pipes are made of galvanized steel and I have had to replace some of the really bad stuff.
I was working on the replacing the bathroom drain and ran into a piece that is 3.5 inches that I am trying to connect PVC to. I have tried using both a 3X3 boot and a 4X4 boot to connect and neither one will work. I also tried using Oakum and some stuff the guy at the hardware store told me to use. I am at the point where I am going to have to call a plumber.
Please help!!! Thanks.
jdsal8 is offline   Reply With Quote
Old 05-06-2012, 10:05 AM   #2
Rewards Points: 87
Go to a plumbing supply company and they will have what you need.
George6488 is offline   Reply With Quote
Old 05-06-2012, 01:31 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Open the clamp farther on a 3" fernco or no hub coupling,spray some wd40 inside the fitting before sliding it on.
God,now I need a shower!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-07-2012, 10:05 PM   #4
Hah thanks for the advice. I'm going to try and "slide it on" but havnt had a chance to try that out. To many DIY projects at once !!
Old 05-07-2012, 10:09 PM   #5
Rewards Points: 6,652
Dawn dishsoap, Ivory dishsoap, etc also works.
Old 05-07-2012, 10:21 PM   #6
Yea that's what a guy at work told me.
galvanized steel frost hydrant amakarevic Plumbing 4 07-26-2009 09:51 AM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 06:47 PM
buried galvanized steel pipe amakarevic Plumbing 6 06-23-2009 03:15 PM
Galvanized steel water pipe-when to replace Audrey214 Plumbing 6 04-28-2009 01:38 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 12:40 PM
