Galvanized Steel To PEX Sizing Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-25-2009, 08:13 AM   #1
Rewards Points: 150
Galvanized steel to PEX sizing issue
Hello all,
I am starting to replace all my steel pipe with PEX as I finish my basement. I thought I would bring 3/4" PEX from the main (it is 3/4" galvanized currently), but I now see that the two are not the same, and that the PEX 3/4" tube is considerably smaller than the steel.
Will that affect my water pressure and current? Should I bump it up to 1" PEX before the hot water heater?
Thanks!
gbwillner is offline   Reply With Quote
Old 12-25-2009, 12:37 PM   #2
Rewards Points: 150
It would depend on your water demand.Are you using the brass insert or push in gator grip?The inserts reduce the flow to about 1/2" where the gator grips with a stiffener insert down to about 5/8". Most house water meters are only 5/8".You could do home runs where each fixtures has a separate H&C pipe coming from a header.You get hot water faster since it's not sitting in a long main cooling off and you get equal flow and pressure.
Hope this helps!
rudolph58 is offline   Reply With Quote
Old 12-25-2009, 06:08 PM   #3
Rewards Points: 150
Hope this helps!
Thanks. I was going to use the brass inserts (with the crimping tool) but I guess I can use the push-in gator grip connectors before the water heater since that will likely take half the flow. I'm not too familiar with these- are they the plastic connectors that do not require crimping but are only a little more expensive?
I do plan to run a manifold for the hot and cold water after the water heater.
Thanks!
Old 12-26-2009, 12:31 AM   #4
Rewards Points: 150
Yes,they are more expensive but a crimp tool for the bands is around $90
Old 12-27-2009, 11:37 AM   #5
Rewards Points: 152
Assuming the galvanized pipe is old, it's probably been choked way down over the years due to scale/barnacles on the inside of the pipe.
I've cut some 1" galv. pipe that's been choked down to the diameter of a pencil.
So, if that's the case, replacing with 3/4" PEX will only show an improvement.
burnt03 is online now   Reply With Quote
Cast iron vs galvanized steel. duffers Plumbing 10 08-04-2009 10:35 PM
galvanized steel frost hydrant amakarevic Plumbing 4 07-26-2009 08:51 AM
Galvanized steel water pipe-when to replace Audrey214 Plumbing 6 04-28-2009 12:38 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 11:40 AM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 10:37 AM
