Galvanized Steel Frost Hydrant - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2009, 04:24 PM   #1
Rewards Points: 1,062
Question
galvanized steel frost hydrant
i just called ferguson and they only carry galvanized steel frost hydrants. since the product is by definition buried and i was told not to bury galvanized steel cause it'll corrode, i was wondering if i should keep looking for a PVC one ? or is this not worth sweating over ? this is for my shed, to which i am running water supply using PVC sch 40.
Old 07-24-2009, 08:19 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
Ayuh,... Where'd you hear That,....I've never seen a plastic 1....
Old 07-24-2009, 08:47 PM   #3
buried galvanized steel pipe
Old 07-25-2009, 12:29 AM   #4
Registered User
Rewards Points: 4,912
C. Dedicated Underground Fire Line
When approved by the Authority Having Jurisdiction, a dedicated fire line may be connected prior to water meter with one main shut-off valve, located in the meter box, painted red, controlling both domestic and fire sprinklers. In which case the following requirements shall apply, see Exhibit B.
1) Underground fire line shall be installed using CPVC pipe that is listed and approved for fire service.
2) Underground fire line shall be inspected and flushed, in the presence of an inspector, prior to connection to sprinkler riser.
3) Depth of bury for CPVC piping shall be 36 inches. From here: http://fire.countyofventura.org/Link...mw%3D&tabid=58
This should help: http://books.google.com/books?id=fFk...esult&resnum=7
Someone may be confused.
Be safe, G
Old 07-26-2009, 09:51 AM   #5
I have never seen a yard hydrant made of anything except galvanized pipe. If it worries you, paint it before installation with a metal paint. You will probably need to wipe the surface down with vinegar to remove the oil on it before painting.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Cast iron vs galvanized steel. duffers Plumbing 10 08-04-2009 11:35 PM
buried galvanized steel pipe amakarevic Plumbing 6 06-23-2009 03:15 PM
Galvanized steel water pipe-when to replace Audrey214 Plumbing 6 04-28-2009 01:38 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 12:40 PM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 11:37 AM
