Old 01-20-2010, 11:48 PM   #1
Galvanized pipe threads ae now smooth in one spot
I am replacing a galvanized pipe which has rusted out badly. This pipe connects to another galvanized pipe in the wall which seems to be a vent pipe as well. Where the rusted pipe sat has destroyed the threads in a 3/4" spot, thus causing my new PVC fitting to leak as well. I used plumber's tape to get a good seal but apparently it didn't do the job. What else can I do short of removing a good chunk of my kitchen cabinets and wall the replace this T fitting in the wall?
Cause of the problem.
The problem.
DJDD is offline   Reply With Quote
Old 01-21-2010, 06:58 AM   #2
It is pretty common for the nipple threads to rust off, but usually the wall elbow is OK. Try multiple wraps of teflon tape and pipe dope, that may work. But I suspect you will need to replace the elbow. And no, it is not a simple job.
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 10:50 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-22-2008 12:48 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
