Galv>brass>copper Gas Pipe Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2008, 08:28 PM   #1
Rewards Points: 41
Galv>brass>copper gas pipe question
I'm connecting a galvanized gas pipe to copper tubing via a brass compression fitting in an outdoor application. Do I have the isolation I need from the copper to the gas pipe to prevent galvanic corrosion?
TIA, Kirk.
kboorman is offline   Reply With Quote
Old 04-07-2008, 09:53 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Havent been in on enough gas stuff yet to know all the ins and outs, etc, but I do know that all of our exterior galvanized pipe has to have the plastic coating on it, and any joints have to be field wrapped.... I don't know the exact material we use, some kind of tape......... maybe someone else can chime in there....
As far as the two different metals meeting, i'm not 100% sure in a gas situation, but water heaters use copper supply flex connected to galvanized nipples....
Journeyman Plumber
Old 04-07-2008, 10:55 PM   #3
Rewards Points: 41
Those nipples should be plastic lined dielectrics to prevent corrosion. They look like a regular galvanized pipe nipple from the outside.
Upon further thought, I guess I should be using flared fittings with gas, huh?
General Pipe Question... slakker Plumbing 7 09-06-2007 12:45 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 09:49 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
