#31 | |
A "G Coupling" installed in gas line?Quote:
No, I was not aware of a gas rated sealant. Which is recommended and how is it applied... on the threads before assemble or on the edges of the fitting after assembly?. Thanks for the tip. |
#32 |
Obviously, I need to close the main gas valve. Do I need to open any lines to allow the remaining gas in the lines to escape for safety purposes?
#33 |
HVAC / Plumbing
apply the dope to the male threads.. If you have a gas wh just fire up the wh . the gas win the lined will be used up
#34 |
A "G Coupling" installed in gas line? |
#35 | |
When you are done, please give us a report on your job. Especially, let us know how the gas leak test came out. |
#36 |
Plumbing Contractor
I havent been on this site in a few days and was just checking this particular thread out.
Someone said something about using a union and if your local gas authority will allow it then by all means go for it. Here we are only allowed to use unions at the appliance being served. Something that we can use are flanges though. Personally I like flanges much more for inline repairs than unions, but as I said, if allowed then go for it. |
#37 | |
I have been having second thoughts on my previous comments about doing this myself. Is not as simple as I originally thought. After reading your input, I have actually changed my mind about it. I guess there is a lot of safety factors and not exactly the place to get cheap. I will have it done by a license plumber. ![]() Thank you |
#38 |
You have made a wise decision. Your insurance (or the licensed contractors) will now cover a fire caused by a leak. This is not true if you do the work yourself.
If you have never made a mistake, you haven't done much. |
#39 |
#40 |
A licensed contractor is responsible for all work done, and any problems caused by his work. This is why they are required to be bonded and insured.
#41 | |
It seems like most licenses are limited to about $12,000. Is that the minimum for most contractors or depending on the trade? |
#42 |
Hard to say. Basically the same as auto insurance. How much can you afford to pay out of pocket, if sued? Some States require a set amount of contractors insurance coverage. Unlikely $12,000 would cover a home burnt down from a bad connection. Insurance is one thing a customer does not understand when a contractor gives a bid, or does a job. It is all a part of doing business. Same a tools needed to do the job.
#43 |
HVAC / Plumbing
most in my area carry 1 million at min
#44 | |
Go here to find out licensing rules in your state, http://www.contractors-license.org/ |
| Display Modes | |
| GFI will not reset will line is hot | soccerdude | Electrical | 15 | 09-07-2008 02:11 PM |
| 230v line for Hot Tub | mstrobel | Electrical | 22 | 09-06-2008 01:11 PM |
| sewer line back fall | oakie14 | Plumbing | 2 | 09-04-2008 06:36 PM |
| Is it normal to change the upper line at the meter when running new supply line? | twilightcall | Plumbing | 3 | 08-08-2008 12:10 PM |
| Telephone line static without external filters installed | Unregistered | Electrical | 5 | 11-21-2004 01:38 PM |
