Old 09-05-2007, 05:31 PM   #1
FYI clogged drains
Just a helpful FYI if you have clogged bathroom drains. I bought a tool called a Zip-It at Home Depot and it works great!! It's a long serated piece of plastic (kinda looks like the zip-ties you get with trash bags only much longer) that you shove down the drain. It pulls up all kinds of hair and crud. Best part is it's only about $2!!
Keyo77 is offline   Reply With Quote
Old 09-06-2007, 05:05 PM   #2
FYI clogged drains
Hair and grease/oil are the biggest part of drain clogs in the bathroom. The grease/oil comes from the dissolved soap and shampoo. I have heard others praise the Zip-it tool. Probably a lot more effective than a bent coat hanger.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-06-2007, 05:48 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
FYI clogged drains
I use enzyme drain cleaner, like DrainCare, that just dissolves all of that gunk and then is flushed down with hot water.
You can get the worst out with a mechanical device like that, but DrainCare cleans it all out to the bare pipe and won't harm the pipe or the tub.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-06-2007, 05:57 PM   #4
FYI clogged drains
I got wrapped up in the tool thing and forgot about drain cleaners. I agree with Mike (as usual) about Draincare. Caustic drain cleaners make a small hole and then run down the pipes to the sewer. Enzyme cleaners cling to and "eat" organic clogs.
pipe size for tub, floor, and bath sink drains amakarevic Plumbing 2 07-25-2007 08:29 AM
Testing Drains bjr23 Plumbing 10 05-09-2007 01:30 PM
tub drains slow new construction clibertyusa Plumbing 5 04-04-2007 01:51 PM
Drains for the A/C Scott_K HVAC 2 06-06-2005 02:07 PM
Sewer Drains Unregistered General Discussion 1 04-24-2004 06:27 AM
