Future Addition-proof Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2013, 01:54 PM   #1
Rewards Points: 89
Future addition-proof plumbing
I am converting an enclosed first floor porch into a mudroom and 1/2 bathroom. Over this area is a sloped roof area/closet (second floor) that I will likely be converting to a master bathroom in the future.
On the first floor, I plan to run a 3" DMV pipe from the 1/2 bathroom toilet to the basement where a 4" pipe awaits. The toilet will only be a foot or two from a planned 3" vertical stack that will run up through the roof on the second floor.
The future master bathroom toilet would be directly over the new 1/2 bathroom toilet (and also a few feet from the vertical stack).
Do I need to run a separate vent for the first floor toilet (now) so that I won't need to add one when the 2nd floor toilet is added?
Thanks,
Todd
toddmanqa is offline   Reply With Quote
Old 06-12-2013, 02:30 PM   #2
DIY staff
Rewards Points: 7,174
In a word--YES--use a separate vent for the first floor toilet--2"---
Old 06-12-2013, 03:28 PM   #3
Rewards Points: 1,958
Please post a drawing of what you intend to do.
Old 06-12-2013, 08:59 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
As ghost mentioned post a drawing its a simple set up but can be tricky getting the combinations correct.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
oh'mike (06-12-2013)
Old 06-13-2013, 09:39 AM   #5
Rewards Points: 89
Diagram Attached
Here is a diagram of what I'm trying to do.
Thanks,
Todd
Old 06-13-2013, 04:20 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
Cant do it that way, are there any lavs tubs showers etc, going in as well?
Old 06-13-2013, 05:20 PM   #7
As Javiles said You cannot do it that way.
You will need to cut in another y in your basement 4 inch and run it to the 2nd floor toilet.
Then vent the second floor toilet about 42 inches above the floor into your existing vent stack. Vent is air only.. No lavs for washing them poop covered hands?
Tags
addition , bathroom , future , toilet , vent
Plumbing an Addition frlowry83 Plumbing 4 04-09-2013 07:56 AM
Subtracting an addition? Opinions? Advice? jl61190 Remodeling 9 01-15-2013 06:06 PM
Water line for addition woody9911 Plumbing 2 01-19-2011 09:34 PM
Future Proof kitchen tripower Electrical 2 06-26-2010 11:55 PM
Insulation from addition to old construction JakAHearts Building & Construction 2 04-28-2010 03:57 PM
