Furnace Running Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2010, 11:20 PM   #1
Furnace running water
My furnace is running water running every five to eight hours. What could be wrong and how can i stop it?
Ceason is offline   Reply With Quote
Old 12-14-2010, 06:09 AM   #2
Not sure I understand. You hot water system is refilling often??? Must be a leak somewhere.
Old 12-14-2010, 06:20 AM   #3
Chicago, IL
Michael Thomas's Avatar
is the exhaust vent pipe on on your furnace made of metal,
or made of plastic?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 12-14-2010, 09:49 AM   #4
Owner
LateralConcepts's Avatar
I would post this in the HVAC forum.. might get more hits.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 12-14-2010, 11:50 AM   #5
Rewards Points: 3,130
My backup furnace does the same thing (it's supposed to). It's a condensing gas unit. The vent is PVC pipe. Since it's below the DWV piping in my crawl space, it has a small pump to route the water over to a drain.
Old 12-14-2010, 12:02 PM   #6
Chicago, IL
The first thing we need to know is if Ceason in fact has a condensing furnace (thus, the vent pipe question).
If so, and the problem is sudden and intermittent (as appears to be the case), and is occurring in the heating mode, it could be something like a disconnected/leaking line on a condensate pump.
If not, and the problem occurs in the heating mode, then he or she likely has a condensation problem in the vent system.
And even it this time of year it's possible that the problem could be occurring in the cooling mode in a few places in the US, in which case it could be a problem in the condensate drain system.
Toilet running water leaking issue? mikehende Plumbing 16 06-01-2009 10:07 AM
Furnace troubles, where's the water coming from... Head Scratcher HVAC 10 03-23-2008 07:40 PM
Water around my steam furnace Volsar HVAC 1 12-11-2007 06:40 PM
Water on bottom of furnace timkay2 General DIY Discussions 5 10-17-2007 08:27 AM
