Funky Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2012, 06:29 PM   #1
Funky vent pipe
Our vent pipe exits through the roof as it should. But where it passes through the attic floor there is a 6inch round opening on the side. some one stuffed rags in it long before we bought the house. over time the rags have fallen out. Should i seal it up? what is this hole?
LisaH is offline   Reply With Quote
Old 04-11-2012, 06:33 PM   #2
Rewards Points: 6,652
Really need pictures showing what you are talking about. As for sealing, yes, due to it causes Chimney effect, along with it is also a easy way for fire to spread up into the attic, if one should happen.
Old 04-11-2012, 06:53 PM   #3
Its not the furnace vent. Its the plumbing vent..old cast iron.
Old 04-11-2012, 07:14 PM   #4
Rewards Points: 350
I think what Greg is saying is that by having that hole open, it is pulling in fresh air through the attic vents, and for a fire to really get rolling in your attic, you need lots of fresh air. Which you now have because those rags are gone. restuff the hole, at a bare minimum, you could be exposing the attic area to dangerous methane style gasses from your septic system.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 04-11-2012, 07:33 PM   #5
Thanks for the clarification. Iget what hes saying. Just cant figure out why theres a hole their in the first place. Ill try to get a photo. Thanks guys.
Old 04-11-2012, 08:06 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 834
I bet someone beat a hole in it to vent a kitchen hood or bathroom fan at some point in time.
I wonder where the pieces went
using section of pipe for both drain and vent amakarevic Plumbing 6 05-11-2011 12:20 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Water leaking from vent pipe die_of_ennui Plumbing 3 03-25-2010 08:11 AM
Hot Water Heater Improper Vent Pipe Danger fritzycat1 Plumbing 2 07-27-2009 10:34 AM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
