Funky 2 Water-heater Configuration? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2012, 08:09 AM   #16
Rewards Points: 1,494
The outlet pipes would not tee back together under the floor. Otherwise none of the fixtures would stop running if you turned off just one heater (either heater).
Old 07-13-2012, 11:32 PM   #17
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
having 2 w/h's in series i believe is the most energy efficient.very easy to tell how. c/w in h/w out to c/w in on 2nd w/h then h/w out.The #1 w/h is the work horse it's the one doing the most heating the 2nd w/h is basically a storage tank but will heat if needed.just having a bigger on will help but 2 in series is the way to go.
wctekkk is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
