Fum Sensor On AO Smith Power Vented WH - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2008, 12:24 AM   #1
Fum sensor on AO Smith power vented WH
......Can it be bypassed by installing a 34k resistor?
I had to go back on a no hot water call for a GPVH 50-100 AO Smith pwr vent WH. The "very hot" and the green "vacation" status lights were lite up but of course the WH inducer was not atctivating.
I went thru the reset procedure but the WH remained in lockout.
I measured the fume senor resistance at 35k ohms. Should have been good but WH still would not fire. I thought there something I was overlooking but factory tech said if the sensor ohmed out OK then I had to change the Valve/thermostat.
I changed both and got the WH back on line.
There are a lot of ceramic paints(Not flameable) in the basement so I am wondering if they are affecting the sensor is it possible to replace sensor with a 35k ohm resistor to avoid nusiance sensor trips?
I am assuming I am not the only one who has wondered about this.
hvaclover is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 05:16 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
