Fully Enclosed Shower Vs Tradtional - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-23-2011, 03:04 PM   #1
Fully enclosed shower vs tradtional
Hello all
I am renovating my master bathroom and I am taking out the bath and putting in a 2 person shower. I have the design more or less worked out which includes glass walls. My questions is what are the pros/cons of having the glass go all the way to ceiling vs leaving 1-2ft of room. Also if I do go all the way to the ceiling what do I have to do differently for the ceiling construction and finish. I plan on tiling the walls at least 7' up but I would like to know if there are any options other then tiling the entire shower.
Thanks for the help
-Johannes
johannes2008 is offline   Reply With Quote
Old 07-23-2011, 05:40 PM   #2
make sure you have a good exhaust fan
Old 07-23-2011, 07:27 PM   #3
I think the major pro of a totally enclosed shower is that it is warmer and hence more comfortable--no cold air circulating into the shower enclosure.
But with a totally enclosed shower all surfaces must be both water and vapor tight or there will be problems down the road.
Bob999 is offline   Reply With Quote
The Following User Says Thank You to Bob999 For This Useful Post:
oh'mike (07-23-2011)
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 02:59 PM
Wire under house not fully enclosed (what wire to use) jamiedolan Electrical 1 02-02-2009 12:47 PM
