Full Port Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2013, 04:10 PM   #1
Rewards Points: 191
Full port valves
Is it important that I use full port ball valves when constructing a bypass for the water softener I plan on installing? Or can I get away with just using regular ball valves?
amateurplumber is offline   Reply With Quote
Old 03-23-2013, 04:14 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
Use Full port especially on the main.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-23-2013, 04:15 PM   #3
Rewards Points: 14,312
Low flow means less pressure at the faucets.
Are check valves required in this situation? chell123 Plumbing 1 02-04-2013 08:42 PM
flow control valves jmon HVAC 9 12-12-2012 10:53 AM
Water Staining Around High Velocity AC Port Nhfixit HVAC 4 12-02-2012 10:46 AM
Stop valves in bathroom while drywalling StevePax Plumbing 11 01-17-2010 05:52 PM
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 06:38 AM
