-   -   Full bath in basement - Questions (http://www.diychatroom.com/f7/full-bath-basement-questions-41840/)
whirly 04-05-2009 09:15 AM
1 Attachment(s)
So i have a standard Builder rough-in for plumbing in my basement. I have framed my bathroom and everything is set in place. The Shower/Tub stub is positioned at 8.5" from the wall to centre drain, and 18" from the side wall to centre drain. I have had three plumbers in and all have different thoughts. The first said that I would have to break the floor in a 12"x12" square around the stub regardless of what i place in that space. The other two didnt know why i would have to do that. If I have to break the floor around the stub, then I would like to put in a stand up shower and move the stub back 2 or so inches ... Otherwise i just would drop a tub in and make the necessary connections ...
Can anyome please help and provide advise?
Anyone had this dilemma with thier basement?
I have attached a picture ...
plumber Jim 04-05-2009 11:40 AM
The reason you need to open the concrete is because the drain piping that will be connected to the tub ie the waste and overflow will set below the tub which will be in some of the depth of the concrete.
majakdragon 04-05-2009 12:17 PM
I agree with plumber Jim. I cannot tell what size the tub drain piping is, but it needs to be 2" for a shower unit. Only needs to be 1-1/2" for tub/shower combo.
Bob Mariani 04-05-2009 02:23 PM
For a tub you need to remove the concrete as posted to make the drain connections. for a shower you will not, you can make a custom base to set the drain where it is or even use a Kerdi drain with systems from Schluter.
majakdragon 04-05-2009 04:00 PM
While Bob Mariani may be correct about the type of base to install, , you need to insure there is a trap under the concrete or add one. Seriously doubt a trap is installed.
zosoplumber 04-05-2009 05:56 PM
Also, the toilet riser that is stubbed up needs to be chipped up around the pipe to get the flange on, unless it is not a 3" pipe and is a 4", but it looks like 3" in the pic, and watch out if it is a standard tub/shower then the pipe needs to be 2" or less off the right wall and around 15" offf the back, unless the tub is wider than 30". if it is a shower "base" than some bases drain connections sit around 1"1/2 inches below the concret in which case you will need to chip up the perimiter of the pipe, now for the 12 x 12 hole they told you to chip up, all that concrete is not needed to be removed just a channel going from the shoe to your pipe.
kenmac 04-05-2009 06:57 PM
I never knew ABS was still being used until I joined this site.. I though everyone had transitioned over to PVC .. No ABS around here.. PVC or ductile iron
Bob Mariani 04-05-2009 07:15 PM
no ABS in CT either, yet Lowes still sells it here.
