Frozen Water Meter - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2009, 07:39 PM   #1
Rewards Points: 162
Frozen water meter
Long story short, but when I visited my cabin this weekend I found that my water meter had froze. The water was valved off ahead of the meter and the heat trace kept the piping from freezing, but I forgot to drain the meter itself. I guess that little 5' vertical section of pipe above the meter is important to drain off
Anyway, it looks like the bottom of the meter was made with a steel plate that was made to break away if it froze. The circular plate broke right along the grooves splitting it into 4 equal pieces. We were able to "rig" it for the weekend to get water, but it leaks at the joint between the bottom plate and the meter body. Can I find a replacement plate from a plumbing supply store, or do I need to call the local water utility? It's a Invensys SR 5/8" meter.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 01-25-2009, 07:45 PM   #2
In my area, you would be looking at buying a new meter! I would think that a call to your water utility is in order!
Old 01-25-2009, 07:47 PM   #3
How much does a water meter cost?
Old 01-25-2009, 07:58 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 660
Ayuh,... 1 cost me about $350. in my water district a couple years ago...
Old 01-26-2009, 12:39 AM   #5
Rewards Points: 562
thats a replaceable part,probably cost 10-20 bucks unless a fine is sorta wrapped in the cost. They are supposed to do that for that very reason. probably a gasket inbetween thats tore or missin. i dont know how they interchange from meter to meter,,,but your utility will help you get one,,,or seek online!!
4just1don is offline   Reply With Quote
Old 01-26-2009, 07:35 AM   #6
Rewards Points: 162
If anyone knows of a source online, please let me know. The gasket is okay - it's just the plate that broke. I was hoping to find one somewhere instead of having to go to the water department with my tail between my legs.
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Frozen Thompson Water Seal.... still work? Ininkus Painting 7 01-05-2009 02:44 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Water meter fitting leaking LanterDan Plumbing 6 04-02-2008 11:39 PM
