Frozen Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 12-12-2012, 09:54 AM   #31
Roofmaster
Rewards Points: 2,210
Pipe
What material is the vent pipe made of, PVC or Cast Iron?
Old 12-12-2012, 12:32 PM   #32
Roofmaster
Vent
OK since you never answered my question re type of pipe, here is what I would try, assuming you have PVC running up through the roof. Cut off the PVC at the attic floor. Install a 3 inch Galvanized Steel or Cast Iron pipe from there up through the roof. Join them with a fernco coupling You can install a riser clamp on the floor, or U-Bolt to a rafter if your close to one. My thinking here is that the cold from outside will conduct down the steel pipe so that the water laden vapor will condense somewhere inside the steel pipe, and run back down. In effect you are moving the dew point down into the pipe.
You can buy a reducing (Increasing) coupling and use it to go to 4 inch CI instead of three, and that would also help, as the ice would have another inch to bridge the opening. It actually sounds like you have a gas appliance connected to this pipe. There is a lot of water in Propane and Natural gas that comes out when you burn it.
I never heard of sewer gas producing enough water vapor to do what you are describing, but that does not mean it cant happen I guess.
Old 12-12-2012, 09:56 PM   #33
Seems like folks aren't reading previous posts. Raychem 7W/foot heat tape can be bought in varying lengths and bunched up and inserted down a vent pipe the distance down through the roof insulation to where it is warmer. I just put a 3" PVC T on top and shoved the tape in one end and down the tube about 18". Problem entirely solved, I have it plugged in all the time and it will not start a house fire. It has gone from -37 to +20 in a snowstorm at present. You folks who can't imagine why a vent pipe would freeze have never experienced Alaska cold.
der Mond is offline   Reply With Quote
Old 12-07-2013, 05:16 PM   #34
Cold froze vent stacks in WY
I have been lurking and watching this thread and others on the topic for a couple years. Having the same issue mainly with subzero temps and windy conditions. Wyoming has tons of wind and lots of cold at times too!
Installed FJ Moore frost proof vents and had some success but froze once last year. Enlarged the vents to 3" from 2" and thought I would be done but the last week they froze again. I got up on the roof and saw light snow/frost "cap" 90% covering the openings of 2 of the 3 vents and #3 was 100% covered. We had temps drop from +60 to zero in 3 days time and have had 4 nights of subzero reaching -25 with 30mph winds. There is no sight of +32 for another few days.
So I have been looking at a lot of ideas and it looks like success is fleeting. except Der mond is confident in his solution from his experience.
I will be getting the no freeze tape and hanging inside the stacks. Can't do it the way he says so I think I will drill in from under the roofline and run the tape up the stack instead of down into it. Hang it from the top and seal the hole in the side of each of the vent pipes.
Just wondering if there are t-stat cubes that will activate at lower than 35 degrees. I have no problems until zero so if I could get one that activates at 10 above I'd be happy.
Another thought, Anyone tried one of the remote control devices like a garage door opener button used for lamps or Christmas lights inside to activate their tape? don't want to be in the attic or on the roof plugging stuff in when it stinks and is stinking cold.
Also not wanting to leave the tape power on when it is not needed. Save power and less chance of short circuit or heating a pipe that does not need to be heated at that time...
I have 3 vents spanning 40" on a roofline so need to figure out how to get them all on with the same switch too. One power source outlet in the attic about 25 ft from the longest point so that will likely be the tap.
mginwyo is offline   Reply With Quote
Old 12-07-2013, 06:52 PM   #35
Rewards Points: 2,032
What about using a circulating pump and hot water from your hwt. Use 3/8 inch pex and wrap your vent with the tubing. Leave yourself a way to drain it down and only use when it freezes shut.
Ghostmaker is online now   Reply With Quote
Old 12-07-2013, 07:57 PM   #36
Well it might work but Seems like one problem for another with running water up to the vents. would have to Figure out a drain once you push the water up there and if it clears the vent, No way you need a flood on a floor somewhere in weather that cold... keeping the water hot enough through the pipe to get it there and do some good... Frozen water down the roof if it breaks for some reason. etc... rather have an electric on off solution I think.
I lived in the S/W US for many years and had no clue issues like this occurred! Fun stuff!
Old 12-07-2013, 10:52 PM   #37
Master Plumber
Javiles's Avatar
Rewards Points: 996
The last time we had a frozen vent pipe weeee.. OOOps sorry iam in south Florida its December and its 80+.... -25 - 55 you guys must be nuts no offense but geees, .. forget about the vent move Miami and lets go boating in December
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-07-2013, 11:15 PM   #38
Rewards Points: 4,080
Go to 4".
That's mostly what you see around here (Winnipeg, Canada) and our temps hover around -40 in January. It doesn't COMPLETELY eliminate the possibility of freezing, but it cuts it down to almost nothing.
Bob Sanders is online now   Reply With Quote
Old 12-07-2013, 11:17 PM   #39
Nah. No offence but it gets a bit boring doing the same thing all year round. Come here though and I'll show you how to strap on some scuba tanks and play ball hockey on the under side of the ice.
Old 12-08-2013, 02:30 AM   #40
What if we used a double wall heat exchanger and circulated antifreeze?
Now no need to drain it.
Old 12-27-2013, 12:00 PM   #41
Frozen Vent Pipe
We installed a 'T' in the attic portion of the vent pipe. The 'T' allows access for inspection and in my case to run a drain cleaning spring-wire snake up the vent.
Our vent had a lot a frost on the vent pipe walls, but the snake went to the top where it met resistance (combination snow-ice cap??). Using the snake like a drain cleaner I was able to bore through and open the vent.
It's cheap, easy and in our case worked.
jag218 is offline   Reply With Quote
Old 02-11-2015, 10:57 AM   #42
Rewards Points: 2
I'm having a having a similar/same problem. I've lived in my house for 14 years, never had this problem until I had my roof reroofed last year. Now everytime the temps drop in the teens or twenties iceicles form on my vent opening at the roof and leak back through. It had to be something the roofer did or did not do. Ideas?
Bill723 is offline   Reply With Quote
Old 01-19-2016, 09:11 AM   #43
Rewards Points: 4
really?!?
to all you fair weather idiots that keep saying stuff like"how could it freeze" you obviously have never been to the prairie states or provinces. yesh. sometimes its -50 for weeks. that how it freezes. not everyone lives where its warm. duh
ktvr3 is offline   Reply With Quote
Old 01-19-2016, 09:14 AM   #44
Rewards Points: 4
ummmm ya no i would rather deal with a tiny frozen vent every now and then then have to put up with hurricanes.
Old 01-19-2016, 09:43 AM   #45
WhatRnsdownhill's Avatar
Rewards Points: 2,220
once you get it unfrozen, either with heat or hot water, you can try making a ubend far enough from the roof line so it doesnt go under snow to prevent build up from snow and freezing rain on the inside of the pipe...if the stack is 3 or 4 inch use 2 90 degree elbows to do this..
WhatRnsdownhill is offline   Reply With Quote
Tags
freezing , pipe , plumbing , vent
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 06:47 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
