Frozen Toilet Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2011, 06:28 AM   #1
Frozen Toilet Pipes
Please help!
One of our toilets froze up last night. It won't flush. What is a safe way to thaw it out? Can I put warm water in the toilet bowl? I think that hot water might crack the bowl.
Actually we got them unfrozen once (and we checked the water meter. It didn't look like we had a leak - but we're really concerned now.) We had below 0 again last night! Frozen again!! We're having very unusual weather here in Arkansas! Our homes probably just aren't made for this. We are in our 70's and we can't crawl under the house.
Thanking you in advance!
_____________________
vinyl windows virginia
broadwille is offline   Reply With Quote
Old 03-07-2011, 06:45 AM   #2
DIY staff
Rewards Points: 7,174
Warm water in the back of the toilet won't hurt the tank---not HOT--
a space heater aimed in the general direction of the toilet and wall behind it will help.
Be prepared for a leak---You didn't mention what your pipes are made of--most pipe stretches as it freezes---repeated freeze/thaw will eventually burst the pipe---(PEX piping can take a lot of freeze thaw without bursting)
I suggest that you get someone to check under the house after the pipe is thawed---
Know where the main shut off is before you thaw--if you have a leak you will want to shut down the water while you wait for the plumber to show up.---Mike---
Old 03-07-2011, 06:47 AM   #3
the Musigician
DangerMouse's Avatar
You'd be safest if you put a small heater in that bathroom and close the door and let it thaw slowly.
...although, I use hot water to clear ice from the car's windshield all the time..... never cracked a windshield yet!
DM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Frozen Pipes? Plugged pipes? brokenhammer Plumbing 7 01-15-2009 11:10 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
frozen pipes helper Plumbing 3 03-23-2008 12:35 PM
"presumed" frozen water pipes mikeinKy Plumbing 23 01-26-2008 11:32 AM
