Frozen Sewer Vent, Can I Safely... - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2013, 10:58 AM   #1
Frozen sewer vent, can I safely...
I live in MN, it's cold. My sewer vent freezes up every 2-3 days. Can I safely redirect my electric dryer vent to my cleanout to help thaw it out from the inside? Any help would be greatly appreciated!
tidal9 is offline   Reply With Quote
Old 12-10-2013, 11:16 AM   #2
Rewards Points: 12,802
Does it freeze up, or does get covered up with snow?
Is this a roof vent or AEV?
Trying to picture how a vent that should have nothing but sewer gas in it is going to freeze.
Got a picture?
Old 12-10-2013, 11:24 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I wouldnt reccomend it myself,it could bring nasty ol methane fumes into house which is not a good thing.
The fumes getting sucked back into your dryer and coming into an ignition source could also be a really bad thing.
Is your stack plastic or cast iron,do you have access to it through the attic?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 12-10-2013, 11:33 AM   #4
Got a picture?
The sewer stack ends up with about 2" of pillowy frost on it, completely sealed, but easily knocked off. Then you have to plunge the hole and remove the frost on the edges, it only seems to be at the very top couple of inches.
Old 12-10-2013, 11:37 AM   #5
Well, I figured it would be better than climbing the roof and traversing across it (sloped with about 3" of snow on it). I figured the dryer exhaust would be enough to push the warmed gases up through the stack and help thaw it out without too much backdraft. The sewer pipe is PVC, unfortunately our attic isn't very accesible, the previous owner built a chute in the attic entrance and had 2 feet of blown insulation put in.
Old 12-10-2013, 02:37 PM   #6
plummen's Avatar
What size is the vent pipe below and through the roof?Around here being your basically southern neighbors next to iowa anyway we are required to increase to 4" atleast 12" below the roofline to help prevent this from happening,it can still happen if the stack gets buried though.
Have you tried leaving the hot water running through the sinks to see if you can get a little heat into the stacks?
Old 12-10-2013, 04:52 PM   #7
An old Tradesmen
Rewards Points: 6,074
Would wrapping some heat tape around 2 foot of the PVC below the roof help the OP any.
Old 12-10-2013, 05:03 PM   #8
I'm not sure what the pipe diameter is below the roof, I can't get into my attic as the PO basically formed a chute and blew 2 feet of insulation in there.
I thought about the heat tape too, I heard there is some you can get by the foot somewhere. I also read elsewhere that someone put some low wattage heat tape into the vent 6-8 inches and let it kinda dangle there. But it seems everywhere you look, folks say it's a fire hazard, maybe the low wattage stuff is safe for PVC...
Frozen Vent Pipe Ratchye Plumbing 55 Today 06:21 PM
The Edge Vent/Smart Vent and leafguard User123 Roofing/Siding 5 07-08-2013 11:31 PM
Concentric Vent Retrofit benchlands Plumbing 4 12-18-2012 05:48 PM
Frozen Sewer kkelsey9140 Plumbing 1 12-17-2009 08:33 AM
Frozen Septic Sewer Pipe. econdave Plumbing 11 03-15-2008 06:00 PM
