Frozen Sewer - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2009, 02:40 PM   #1
Angry
Frozen Sewer
We have about one hundred and forty feet of distance between access holes into the sewer line. Somewhere in there the line has frozen shut and we are currently trying to thaw it out. We are using a home made steamer that is sort of working but we are looking for better results. Any ideas would be helpful. also does anyone know if there is pipe out there with built in heat tape or something of that sort.
kkelsey9140 is offline   Reply With Quote
Old 12-17-2009, 07:33 AM   #2
Rewards Points: 1,492
Are you able to pump in large quantities of steam, working from the low side (the outlet side) that the water condensed (the condensate) from the steam doesn't interfere with the steam's hitting the obstruction?
From the high side you would want to poke down a hose all the way to the obstruction to express the steam down there to heat up any accumulated water (including condensate) as opposed to being blocked from the area of the obstruction by accumulated water.
Actually they do make pipe with a built in heating cable, for such purposes as temporary over the ground water mains. You can see a "spiral molded into the pipe surface". This is not a do it yourself project.
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Frozen Septic Sewer Pipe. econdave Plumbing 11 03-15-2008 05:00 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
