Old 01-15-2009, 10:49 PM   #1
Default Frozen Pipes? Plugged pipes?
I have an issue with the hot water supply pipes in a slab home.
The home is occupied and the cold water flows freely to all faucets and the tub. The hot water only flows out at one location, the washing machine, which is much closer to the water tank and in the opposite direction of the other hookups. I suspect the hot water water T's and part goes to the washer and the other part of the T supplies the rest of the house. The supplies run along an exterior wall at some point. There is no evidence of any burst pipes. Is it possible for a hot pipe to freeze and not burst? The pipes are both behind a wall and they do not run side by side. I did run some water out the drain in the water heater and it was plenty hot..... Any ideas? Anyone seen something like this before?
thanks
brokenhammer is offline   Reply With Quote
Old 01-15-2009, 11:03 PM   #2
Low Water Pressure Fixer
Default Pipes
What comes out of your other faucets from hot, just nothing or a little?
ASEflorite is offline   Reply With Quote
Old 01-15-2009, 11:13 PM   #3
nothing at all will come out when hot is turned on.
Old 01-15-2009, 11:25 PM   #4
Default Pipes
Whats the temp outside? Sounds like it could be just frozen then. I wont burst right away but, its an time bomb if this is the case. Its possible that you had a major encrustation collapse after the washer with does happen but only over time. Did it happen just like quick or have you not used it for a short while.
Old 01-15-2009, 11:25 PM   #5
Master General ReEngineer
Ayuh,... Entirely Possibly,.... Probably the Issue...
Turn On the faucets downstream,+ try to get some air around the pipes if possible...
Old 01-15-2009, 11:43 PM   #6
stupid question, but have to ask..Did you check the stops at the faucet and made sure the hot is on. If yes, then hot pipes will freeze they should all be insulated at exterior walls and unheated space. Pex will actually freeze and expand with the swelling of the ice, wich is not likely with coppe
zosoplumber is offline   Reply With Quote
Old 01-16-2009, 12:29 AM   #7
what KIND oif pipe and how far the run??
Plus how cold it it there now?? Like general area?? Where ya from??
IF you can get easily to a big water line,,,not a 1/4 inch faucet line,,,you can pass a small copper tube down a straight run to freeze area,,if a mess might keep the wet vac running.
Can you insulate this pipe without tearing down half the house?? Even drilling drywall and squirting in foam??(depending on your temp, outside, answer!!)
4just1don is offline   Reply With Quote
Old 01-16-2009, 01:10 AM   #8
Yes. It has been pretty cold. I'm in St. Louis. The line is copper.
I didn't know pex would expand and would potentially be more durable under these conditions. It's supposed to get a little warmer tomorrow, so hopefully I've weathered the storm for a little while..... the downside of all of this is that it's in an occupied rental home.....
thanks for the tips.... i guess I'll spray some insulation behind the wall next time I'm there...
More On This Topic
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
We are going to talk a little bit about how we are going to get water to our shower, our toilet, our new washing machine, and our sink. What I had to do was I had to find a place where I could pull cold water and also pull hot water and being that these... Read More »
Taking copper pipes apart may be necessary if you're remodeling an older home or if you have a leak between a pipe and a fitting. It's a job the home handyman can handle with the right tools. Just follow the steps below. Read More »
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 03:18 PM
frozen pipes helper Plumbing 3 03-23-2008 02:35 PM
"presumed" frozen water pipes mikeinKy Plumbing 23 01-26-2008 01:32 PM
Assistance to Prevent frozen Pipes in an overhang/candlever PLEASE nitro4you Plumbing 3 11-14-2006 10:41 PM
Drain Pipes, Walls and Studs mattaparity Plumbing 1 11-02-2006 09:44 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
