Frozen Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2013, 01:23 PM   #1
Rewards Points: 346
Frozen pipe
Very cold last night, below zero F.
One pipe in the house must be frozen, there is no water coming out of it. It's the hot water in the kitchen sink (should have left the cabinets open, maybe). I did put a space heater in the cabinet and closed it up, ran it for an hour. Whew, was like a sauna in there!! Still no flow. This house was a foreclosure and clearly, pipes leading to the kitchen sink had frozen as the ceiling downstairs was cut out in that area, and pex had been spliced into the copper to fix the bad parts.
There is no leaking in the basement, at least the sheetrock ceiling isn't showing it yet! How concerned should I be about the pex splice, should I cut open the ceiling or give it more time? If I stick my hand under the kitchen sink where the hot water comes up, I can feel cold air coming up around the pipe, so clearly the insulation in that area isn't up to snuff or I have an air leak to the outside. Oddly, the cold water right next to it did not freeze.
Appreciate any ideas!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 01-03-2013, 01:29 PM   #2
Rewards Points: 13,300
Warm water freeze first, long story why.
Any way to get at it from under the house? Far more likly it's frozen under the house then in a cabinet inside the house.
Are all the vents closed under the house?
Did someone at least insulate the pipes under the house?
Old 01-03-2013, 03:55 PM   #3
Rewards Points: 346
The pipes are in the basement ceiling...which I just finished painting this weekend after mudding and sanding! Still no hot water, so my gut is telling me I will have to cut that ceiling open, see what's up in that area. Maybe a lack of insulation, or a hole where an old gas line came in from outside. But it must be very cold in that area to still not have thawed.
So no, Joe, there is no other access to the pipe other than under the sink, and in the basement ceiling.
Old 01-03-2013, 03:59 PM   #4
Rewards Points: 736
Are you sure there's not just something wrong with your faucet or something silly? I can't see how a single hot water line would freeze if yo uhave an enclosed basement. Other hot water in the house works right? Is the sink on an exterior wall even?
TheBobmanNH is offline   Reply With Quote
Old 01-03-2013, 04:01 PM   #5
DIY staff
Rewards Points: 7,174
bad news---you will need to open the ceiling----first to thaw and check the condition of the pipe and second to find the air leak/lack of insulation.
The last one I had like that ,I found a hole through the rim joist for some long gone pipe--hidden by a deck----
dougp23 (01-03-2013)
Old 01-03-2013, 05:08 PM   #6
Rewards Points: 346
I have checked, but it's just me and the wife and she doesn't know how to shut off a valve! So it's nothing silly, unfortunately. No other faucets have any trouble. Sink is on an exterior wall...
Old 01-03-2013, 05:11 PM   #7
Rewards Points: 346
Mike, I hate your post ;-) but I am pretty resigned that you are right. If the pipe froze this time, it will freeze next super cold time.
I just worry about that PEX spliced into the copper....it's just a pressure like fitting or something. Hope it's not drip-dripping away in the basement ceiling.
Thaw with a hair dryer, right? Cut with a keyhole saw, lol!
Old 01-03-2013, 07:41 PM   #8
Rewards Points: 346
Well, cut open the ceiling, and oh yeah, LOTS of cold air coming in. As you can see in the attached picture, for some reason a portion of the wall "bumps out" about 3 or 4 inches. If you reach in where the pipes are and stick your hand down into that bump, LOT of real cold air coming in. Not only that, a few inches beyond the bump is the outside wall. The basement is largely underground with about the top 2 feet exposed. So plugged it all up with insulation (I know the rest of the wall is insulated, the lower half was all exposed when we bought the house, and it was insulated, thinking maybe the insulation "settled" at the top?) . Get the wifey to let me borrow her hair dryer, and in a few minutes, hot water.
No leaks, pipes looked good. Hope I fixed it. Now my nicely finished ceiling looks like crap, lol!
Old 01-04-2013, 12:27 PM   #9
Rewards Points: 1,452
Before you close up the ceiling, double check and do not have any insulation between the pipe and the living space, namely don't put a layer of insulation between the pipe and the new ceiling drywall.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
drtbk4ever (01-04-2013)
Old 01-04-2013, 03:06 PM   #10
Rewards Points: 346
Thanks. Is that to give the pipes heat from the living space?
Old 01-05-2013, 12:14 PM   #11
Yes.
For this reason I recommend putting pipes in exterior walls in front of the insulation instead of nestled within the insulation. For new work, either slide the insulation behind the pipe or cut a V shaped notch, as wide as the pipe is deep, out of the insulation batt so as to expose the pipe.
oh'mike (01-05-2013)
What kind of ABS or PVC pipe cutter do you prefer Pirulo Plumbing 10 09-18-2012 01:12 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 01:50 PM
