Frozen Line From Well - Dont Know What To Do. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2014, 10:28 AM   #1
Frozen line from well - dont know what to do.
We have no water coming in from the well and suspect it is a frozen line. The line is actually something more like plastic (not sure of correct name). So we are not sure how to unfreeze it. there is one area in our back yard where the line goes along the house and under the back door, and suspect this is where is is frozen. Is there any way to fix this before calling in someone?
Ceelbe8 is offline   Reply With Quote
Old 02-07-2014, 10:36 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Put a couple of heaters or halogen lights on it, hit it with a hair dryer until you get water.... (don't get the heaters or light too close to a plastic line)
After that, insulate the line well when a freeze is expected.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Ceelbe8 (02-07-2014)
Old 02-07-2014, 12:06 PM   #3
Rewards Points: 734
For lines that are too shallow but not exposed enough to heat conveniently I've added straw on top of the area about 2 ft. deep to thaw buried lines.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 02-07-2014, 02:23 PM   #4
Master Plumber
Benplumbing's Avatar
Drain a few 5 gallon buckets of hot water from your water heater open up the cap outside and pour down the well as fast as you can. the adapter that connects to your well might be frozen have had a few of those this year
Benplumbing is offline   Reply With Quote
Tags
frozen , water tank , water well
Condensate Drain Line Mystery flhvac HVAC 9 06-02-2013 12:08 AM
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 08:09 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 12:19 PM
frozen city sewer line marystrand Plumbing 2 06-17-2010 07:13 AM
Frozen cold line, not hot... Unregistered Plumbing 1 06-08-2006 08:42 AM
