Old 01-06-2008, 11:05 AM   #1
Post
frozen gas line connection
I'm relocating a gas range and relocating gas lines to fit new location
one of the old connections cannot be loosened. any advice on loosening the connection or is it just brute force?
fisherziggy is offline   Reply With Quote
Old 01-06-2008, 12:31 PM   #2
Oldguy
Rehabber's Avatar
2 - 24" pipe wrenches. One to hold the stationary end, the other to turn the other end (yea brute force)
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-06-2008, 12:37 PM   #3
Send a message via AIM to Marlin
Yup, you probably need a larger wrench. Most of the time when someone has a stuck fitting it's because they're trying to use a 12in wrench on a fifty year old rusted 1in fitting. Don't forget to hold back though.
Marlin is offline   Reply With Quote
Old 01-06-2008, 02:03 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Larger wrenches than you've tried, or use a cheater pipe on the handle of the largest turning pipe wrench that you have for leverage.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-06-2008, 03:37 PM   #5
Yep, Time for your Tim the toolman imitation,,,MORE POWER!!!uugh uugh,
justdon is offline   Reply With Quote
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 08:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
Frozen cold line, not hot... Unregistered Plumbing 1 06-08-2006 08:42 AM
