Frozen Drainage Hose - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2011, 03:01 PM   #1
Hey guys,
I live in ND and I didn't get a chance to take off my drainage hose before we started getting snow, and now my sump pump is running non-stop. The plumber said to disconnect the hose because its probably froze and is starting to backup. I dug through the snow and got it disconnected, but all I see is ice in the pipe coming from the house. Is there a way to thaw it out? What should I do? My basement isn't flooding, but the room where the sump pump is also has the water heater and water softener in it, and its causing a lot of condensation in that room. Any suggestions? Is this something I should do myself, or should I call the plumber back?
Please help.
elway-07 is offline   Reply With Quote
Old 02-22-2011, 04:48 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
Take a hair dryer or CAREFULLY use a paint stripper heat gun on low setting and warm the pipe where it goes thru the wall. The plumber is going to do the same procedure.
Old 02-23-2011, 10:34 AM   #3
Update...
I used a hair dryer and managed to thaw the ice build up so it's now flowing. Thanks for the help.
Old 02-23-2011, 10:40 AM   #4
Owner
LateralConcepts's Avatar
Originally Posted by elway-07 View Post
Update...
Good to hear! Hey, curious what part of ND are you in?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Frozen outside faucet leaks -> Hose left attached k6trouble Plumbing 13 07-01-2013 12:29 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 01:52 PM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 02:22 PM
Permanent sump pump drainage hose jools Plumbing 8 05-11-2008 10:37 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
