Frozen Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2010, 09:39 PM   #1
Solutions (handyman)
Rewards Points: 362
Frozen Drain pipe
I believe a customer of mine has a frozen drain pipe and need suggestions as to the best way to fix the issue. It is a 4" pipe, underground, that runs from the house to a septic system, about 250 feet. I'm not sure where the blockage is but fluids have backed up into the house (a little bit). Any suggestions would be appreciated.
Mark Harvey is offline   Reply With Quote
Old 01-08-2010, 10:26 PM   #2
Rewards Points: 1,418
If it is indeed frozen then you have not choice but to melt it.
The fastest way is to call in someone who can put a hose down the drain all the way to the blockage and pump in live steam.
Old 01-10-2010, 06:03 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
call somebody with a main line machine to cable it out
plummen is offline   Reply With Quote
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 11:32 AM
closet flange ....over the drain pipe or inside the drain pipe moegumble Plumbing 2 08-18-2009 08:09 AM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
Joining ABS p-trap under shower to C.I. drain pipe warriorfox Plumbing 4 01-01-2009 02:29 AM
bathtub drain in concrete - tail pipe questions amakarevic Plumbing 7 06-17-2008 10:50 PM
