Frozen Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2013, 11:27 AM   #1
frozen drain
my water was froze for 4 days it broke at the main shutoff and was spraying water for a few hours underneath mobile home.got someone to change it and he put new pipe in,got water back but when i went to flush the toilet it backed up into tub same with bathroom at other end of house sink washer everything keeps backing up used a salamander heater for several hours under house but still nothing any help would be appreciatedp.s cant afford a plumber for at least 2 weeks and cant go that long without shower washer toilet dishes.
captain12974 is offline   Reply With Quote
Old 01-27-2013, 11:36 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,.... It's hard to say Where it's frozen, other than it's Somewhere in the sewer pipin'...
Heat it where ya Think it's froze, 'n hope ya get it right...
Old 01-27-2013, 11:41 AM   #3
the problem is the entire pipr feels cold so really no way to find the exact spot wasnt sure if there was anything besides heat i could try
Old 01-27-2013, 11:43 AM   #4
Rewards Points: 1,236
If there is no under pinning around the structure to retain some heat your best option is to heat trace (tape) and insulate the exposed pipes and hope none of them split from expansion.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
captain12974 (01-27-2013)
Old 01-27-2013, 11:44 AM   #5
Bondo's Avatar
Ayuh,... It's Probably where it exits the heated area of the trailer, where there's less pitch to keep it movin'...
While it's possible that Salt could help, I'm guessin' gettin' the salt to where it'll help, probably ain't possible...
Gettin' the frozen area to above 32 is the only way I know of...
The Following User Says Thank You to Bondo For This Useful Post:
Old 01-27-2013, 02:00 PM   #6
There should not have any water in the drains line. Could freeze at the p-trap for the shower or tub. Sound like you got a clogged sewer line.
best handyman is offline   Reply With Quote
Old 01-27-2013, 04:17 PM   #7
Roofmaster
Rewards Points: 2,210
Can you insulate around the base, and use a kerosene jet heater pointed under there? That should work pretty fast, I would think. Just dont burn your place down. Better dirty than homeless. Have you tried boiling water down the traps? OK Boiling Salty Water.
Old 01-27-2013, 04:52 PM   #8
Rewards Points: 13,712
When I lived in NH we had to have solid skirting, all the water lines and drains had heat tape, insulation then pressure treaetd boxing around all the lines.
One winter I saw lines 24" below ground freeze up.
Old 01-27-2013, 07:10 PM   #9
On a drain line the only thing that can freeze is a p-trap. Don't they pitch the pipe under a trailer.
Old 01-27-2013, 07:46 PM   #10
It's pitched but I've often seen them run above ground for some distance before going under ground to the tank.
Old 01-27-2013, 10:11 PM   #11
Get some trash bags and a five gallon bucket, cut the tub drain run it on the ground, wash dishes in the tub. Does it drain at all. Where are you? How would the drain freeze and not the pipes. Must be frozen under ground. If it drains, run the sink and see how long it takes before overflowing.
paintdrying is offline   Reply With Quote
Tags
frozen , frozen drain
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
How to dislodge frozen drain escutcheon noquacks Plumbing 5 11-10-2012 01:08 PM
setting a shower drain Jackets Plumbing 16 05-10-2012 08:48 PM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
