Old 06-16-2010, 07:48 PM   #1
frozen city sewer line
how far below the ground does the freezing that causes problems begin at
marystrand is offline   Reply With Quote
Old 06-16-2010, 07:56 PM   #2
concretemasonry's Avatar
If you connecting to a city sewer line the elevation of the existing line is what controls. THis is not the same as the frost level because of the heat normally carried by a sewer line contnts and the. - Not like preventing a footing in an unoccupied building from heaving.
Dick
concretemasonry is offline   Reply With Quote
Old 06-17-2010, 07:13 AM   #3
It depends on where your located, up here in the northeast, drainage piping is required to be installed 4 feet below grade, water piping 5 feet below grade. The further south you go, the frost line is higher, so the drainage piping can usually be installed higher in the ground.
The Engineer is offline   Reply With Quote
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
cement truck over sewer line SAS Plumbing 20 03-24-2009 10:07 PM
Frozen cold line, not hot... Unregistered Plumbing 1 06-08-2006 08:42 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
sewer main line repar Babar Plumbing 1 01-26-2004 07:39 AM
