Frost Proof Hose Bid Replacement Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2009, 03:16 PM   #1
Frost proof Hose bid replacement question
Left the hose on and the hose bib froze. Have access panel to plumbing PCV lines. Cant see how the metal end of the bib connects to the 1/2 inch PVC pipe. I have drilled out the mortar so the bib is loose in the brick outside, but am wondering if the hose bib threads onto the PVC pipe or is glued on? I could cut the PVC pipe inside the basment to pull it out but If the conection is threaded could I just unscrew it ? How do they normally connect Hose bibs to PVC pipe? If I can avod the gluing and cutting I would like to...
Crush is offline   Reply With Quote
Old 07-25-2009, 04:42 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
By either a moale or female adapter off the PVC
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Replacement window nailing fin question gortman Building & Construction 7 11-28-2006 07:33 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
Wet Flooring Replacement Question RetroActv Flooring 1 04-03-2006 04:57 PM
Torch Roof Replacement Question Chad262 Roofing/Siding 6 09-21-2005 07:29 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
