-   -   Frost proof Hose bid replacement question (http://www.diychatroom.com/f7/frost-proof-hose-bid-replacement-question-49612/)
Crush 07-25-2009 03:16 PM
Left the hose on and the hose bib froze. Have access panel to plumbing PCV lines. Cant see how the metal end of the bib connects to the 1/2 inch PVC pipe. I have drilled out the mortar so the bib is loose in the brick outside, but am wondering if the hose bib threads onto the PVC pipe or is glued on? I could cut the PVC pipe inside the basment to pull it out but If the conection is threaded could I just unscrew it ? How do they normally connect Hose bibs to PVC pipe? If I can avod the gluing and cutting I would like to...
Plumber101 07-25-2009 04:42 PM
By either a moale or female adapter off the PVC
