Frost Hydrant Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2010, 11:44 AM   #1
Rewards Points: 1,062
Question
frost hydrant installation
i just hooked my shed's frost hydrant into water supply 3 ft under and have not backfilled yet. when testing, i noticed that it has a small release vent in the bottom to release residue water after it is shut off. so, before i backfill, my question is should the area around the bottom of the hydrant where it connects to the pipe be GRAVEL instead of DIRT so that the water has more empty spaces around gravel pieces to drain through ? seems like the perfect choice, just wanted to confirm.
thanks
Old 08-22-2010, 12:02 PM   #2
thanks
I usually use river rock, and I wrap it in plastic so that dirt can't work its way in over time
the_man is offline   Reply With Quote
Old 08-22-2010, 12:13 PM   #3
Question
but gravel should be fine, no ?
Old 08-22-2010, 12:52 PM   #4
yea i think it would, just make sure there isn't a lot of dirt or fine material in it, and wrap plastic around it all to keep dirt and roots out
The Following User Says Thank You to the_man For This Useful Post:
amakarevic (08-22-2010)
Old 08-22-2010, 01:40 PM   #5
Rewards Points: 867
gravel is the best, i use it all the way to the surface. make sure that there is nothing close to that vent hole to plug it. i usually fachion some bricks or rocks around the hole to keep anything from getting close, then backfill.
TimPa is offline   Reply With Quote
Old 08-22-2010, 02:34 PM   #6
I don't use gravel, I've always worried about it compacting too much and not working after a few years. I would imagine if you use it all the way to the surface you might not have that problem, but thats a bit overkill for me.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 05:56 PM
galvanized steel frost hydrant amakarevic Plumbing 4 07-26-2009 08:51 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
