Old 05-15-2009, 07:57 AM   #1
frost free outdoor faucet question
I have one that works, accept when I use it ,water squirts all over the place. a careful inspection led me to see that the male threads, where you attach the hose are lacking in two areas opposite each other. Naturally, the water has a way to escape in those to areas. This faucet is about 20 years old.
Is this a deliberate design, meant to prevent the freeze ups or would i be able to replace it and enjoy a squirt free experience, esp when I turn off the water and undo the hose? thank you for anyone who can answer! roberta-mos
Roberta-mos is offline   Reply With Quote
Old 05-15-2009, 09:05 AM   #2
A picture would help but if the part where the hose contacts the bibb is flat it should seal even it the threads are missing. Some are squared off to accept a wrench. Could it be the hose washer is bad or missing?
Rege
RegeSullivan is offline   Reply With Quote
Old 05-15-2009, 12:21 PM   #3
sorry, I should have mentioned that I replaced the washers at the time, thinking , huh, I can fix this! The male threaded part looks like it is not part of the faucet, but, although it easily goes around, is not removable. roberta
Old 05-15-2009, 01:33 PM   #4
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
THAT IS A ANTI-SIPON DESIGNED TO KEEP YOUR HOSE FROM SUCKING
UP BAD THINGS OFF YOUR YARD LIKE DOGGY POO, OR PESTICIDES
WHEN YOU LEAVE THE HOSE ON THE GROUND RUNNING,
IF IT'S SQURTING WATER YOU NEED TO REPLACE HOSE BIB WITH A NEW FAUCET THAT ALSO HAS A/S ON IT THEY ARE MADE TO BE NON--REMOVABLE ON PURPOSE
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 05-15-2009, 02:43 PM   #5
thank you JerryMacplumb !
Old 05-16-2009, 01:15 PM   #6
post a pic so we can better understand what you are talking about and where it is leaking
al's sewer is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 9 03-22-2011 09:40 PM
frost free outdoor faucet etainabfr Plumbing 5 05-02-2009 10:59 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Frost free sillcock white29 Plumbing 5 04-29-2008 11:38 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
