Frost Free Outdoor Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2009, 02:28 PM   #1
frost free outdoor faucet
The top nut holding the plastic assembly in place has begun leaking. I tried tightning and have made it worse. Is this repairable or must I replace the whole faucet ?
Roger
etainabfr is offline   Reply With Quote
Old 05-01-2009, 04:28 PM   #2
Custom Cabinet Maker
more than likely in the big picture just way easier and faster,better to just change it
skymaster is offline   Reply With Quote
Old 05-01-2009, 06:31 PM   #3
Safe, Most of the Time!!
brokenknee's Avatar
Are you talking the packing nut? You should be able to repair it.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 05-01-2009, 07:29 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
The first "plastic assembly" that comes to my mind when talking a fp hosebib is the vacuum breaker. There are repair kits available.
JDC is offline   Reply With Quote
Old 05-01-2009, 07:38 PM   #5
Chicago, IL
Michael Thomas's Avatar
If its a 300 and 500 series Mansfield (the most common type here in Chicago) it sounds like you may have a broken vacuum breaker (I often see this at home inspections), if so there is a repair kit:
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 05-02-2009, 09:59 AM   #6
Your advice is noted, thanks.
Roger
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Attic Frost cougar01 Building & Construction 5 01-28-2009 08:33 AM
Frost free sillcock white29 Plumbing 5 04-29-2008 10:38 PM
