Frost Free Hose Bibb Replacement Through Brick Siding - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2012, 05:54 PM   #1
Frost Free Hose Bibb replacement through brick siding
Recently our exterior hose bibb froze and busted because the garden hose was carelessly left on the foucet. It was mortared tightly in place when the house was constructed. I had to saw off the pipe before the flange to remove it. Now that I want to install the new one, it catches on the outside lip of the pipe. I would like to make it professional as possible. I like how tight it was before. I will have to atleast try to chisel or dremel tool enough mortar to allow me to insert it all the way through. Any suggestions to how to seal around pipe, as I push it through the brick opening? Also want to use plastic screw anchor in mortar/brick for plastic flange.
Morgan R is offline   Reply With Quote
Old 03-12-2012, 06:19 PM   #2
Experienced
Jackofall1's Avatar
Make the hole big enough for it to slide through and when its about an inch away from the brick apply some poly sulfide caulk to the area of penetration. Apply enough so the valve body seats into the caulk.
Poly Sulfide can be purchased at any marina as a single part caulking.
Mark
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Frost Free Spigot Repair BatmanDIY Plumbing 2 04-13-2010 08:53 PM
Strange faucet (hose bibb) pjpjpjpj Plumbing 7 08-24-2009 08:12 AM
frost free outdoor faucet question Roberta-mos Plumbing 5 05-16-2009 01:15 PM
Frost free sillcock white29 Plumbing 5 04-29-2008 11:38 PM
