Frost Free Faucet - Cannot Turn On - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2011, 08:56 PM   #1
frost free faucet - cannot turn on
I have a brand new house. I have a sillcock frost free faucet installed and wanted to turn on to wash car. \does not have any flow. Cannot figure how to turn on ..turn all the way on,,nothing happens....been working on this now hours with no success...any one who can help....never tried this before,,,desparate
terrealta is offline   Reply With Quote
Old 04-02-2011, 10:02 PM   #2
What kind is it? Do you have a pic you could post?
VIPlumber is offline   Reply With Quote
Old 04-02-2011, 10:24 PM   #3
i think this is it
BII 0865-120
http://randolphindustrialsupplies.co...%20Faucets.pdf
I believe this is the one, found by google # on tap
Old 04-03-2011, 07:42 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Is there a shut-off valve inside the house?
Many plumbers isolate hose bibs this a shut-off valve.
tcleve4911 is offline   Reply With Quote
Old 04-03-2011, 02:20 PM   #5
not that i can see, runs direct of header
Old 04-03-2011, 02:33 PM   #6
These frost free faucets have a long stem with a standard washer and seat at the end.
The washer can be replaced from time to time, if they become worn out.
To change a washer, the hex head is unscrewed, and the stem drawn out.
If you loosen the hex head, water should start to run when the stem is removed.
If it doesn't run, it means that the water supply isn't reaching the valve.
Keep in mind that if there is water to the valve, it will squirt all over the place, so be ready to tighten it back up if you don't want to get soaked yourself!
Old 04-03-2011, 02:58 PM   #7
firehawkmph's Avatar
Rewards Points: 1,858
Some of the frost proof faucets have a spring loaded washer and seat arrangement. When they sit for awhile in the closed position, they may stick together and not release when you turn the handle. I would shut off the water at the main shutoff if you don't see a separate shutoff for this hosebib and then take the handle and stem out. Check the washer and make sure it's not melted or deformed and then put it back together and see if it works ok then.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 04-03-2011, 03:53 PM   #8
Mike Hawkins
I took out the stem, yes it had a sping at the end, yes. I put it back together again, both with my main water shut off on and off....no water seems to be getting to this tap.. I'm completely puzzled...It's the weekend and I wanted to wash the car..looks like I'll have to wait to call the installing plumber....I have no idea what's up !
Old 04-03-2011, 04:28 PM   #9
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Let us know when you find out.....
Old 04-03-2011, 06:18 PM   #10
Terre,
There has to be a shutoff somewhere along the line. Start by your main shutoff and work your way over to the hosebib and see if you can find it.
The only other thing I can think of is if the plumber forgot to tie in that section of the plumbing, but I can't say I ever saw that happen. When I was building new homes during the 90's and early 2000's, I would go around and turn on each faucet and flush all the toilets etc., just to make sure they worked and didn't leak, before the owner's took possession of the house. And in many cases, the inspector would do the same during the final inspection.
Mike Hawkins
Frozen outside faucet leaks -> Hose left attached k6trouble Plumbing 13 07-01-2013 11:29 AM
Good grief, 1956 American Standard bath faucet repair problem David911 Plumbing 4 02-27-2010 04:33 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Bathtub faucet stem seat is frozen and won't turn. Husky Plumbing 1 04-01-2009 01:35 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 01:25 PM
