Front-loading Washer Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2009, 10:51 PM   #1
I want to move my front loading washing machine, but have a question about the drain. The manual says to drain it into a standing drain pipe. However, can that pipe then run horizontally with 1/4" or 1/8" slope to connect to the main drain? Or will the pressure cause the water to backup? I'm not sure how hard a front-load washer pumps the waste water. Perhaps if I put in a 4" drain, it won't matter? Any thoughts?
Thanks!
Chris
cbeingessner is offline   Reply With Quote
Old 09-09-2009, 08:03 AM   #2
Washer drains are to be vertical. They also require a trap. Newer codes are requiring 2" drains instead of the traditional 1-1/2" since newer washers have faster and more powerful pumps. Aside from any Code violation, I think this would cause you problems with drainage.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-09-2009, 10:27 AM   #3
Do you mean that washer drains have to run directly into a main stack? (With the trap in place, of course.) Looks like I may be breaking out the jackhammer
Old 09-09-2009, 10:36 AM   #4
Not saying "directly" into the main stack, just that they require a trap, the same as any other fixture.
Old 09-09-2009, 10:44 AM   #5
So can I put in a vertical standing pipe, with a trap, and then from the trap run a horizontal pipe with 1/4" per lin foot of slope to my main stack? I'd have to cover about 10' of distance. Or would this be a code violation?
Old 09-09-2009, 10:56 AM   #6
Not sure what your local codes are, but it would work where I have worked and lived.
Old 09-09-2009, 11:01 AM   #7
Right on. Thanks for the help!
Old 09-09-2009, 03:48 PM   #8
GC/Master Plumber/Mech
Rewards Points: 560
That would really be a violation. Using 2" pipe from a trap can only run horv for eight feet.
Max distance from a trap on a horz run
1 1/4 = 5 ft
1 1/2 = 6 ft
2 = 8 ft
That is uniform plumbing code 2006
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-09-2009, 06:55 PM   #9
Plumber101, thanks for the input. This is why I stated about local codes.
Old 09-09-2009, 11:33 PM   #10
It should also be vented.
plumber Jim is offline   Reply With Quote
Old 09-10-2009, 04:40 AM   #11
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Are you saying that the horizontal can only run a total of 8 feet or that 8 feet is the maximum trap to vent distance? Just curious. Where I'm from, you can run the horizontal as far as you need to as long as a vent is within 8' (for 2") of your trap.
JDC is offline   Reply With Quote
Old 09-10-2009, 08:46 AM   #12
Rewards Points: 1,532
With more than 8 feet horizontal distance, the water won't flow fast enough down the drain pipe for the gallons per minute output from the washing machine, even with venting.
There are probably some figures for fatter drain pipes or greater slope for the "horizontal" run allowing for a greater distance from the machine to the main drain, although I don't know what they are.
Old 09-12-2009, 09:10 AM   #13
Thanks for all the help -- after some consideration, we're going to enlarge the basement bathroom, and put the washer/dryer in there as well...Simplifies the plumbing issue!
Chris
Old 09-12-2009, 09:58 AM   #14
Rewards Points: 560
[quote=AllanJ;326037]With more than 8 feet horizontal distance, the water won't flow fast enough down the drain pipe for the gallons per minute output from the washing machine, even with venting.
And that just ain't true...
The reason you can not run a horz drain from a traped fixture more than eight feet to a vent or verticle drain is the water in the trap weir could be removed leaving a void in the trap so that sewer gas can escape.
Now your statement could be true if the main drain is not sized correctly for the total nimber of DFU's to drain into the 2" pipe
Tags
drain slope
LG Front Loading washer on second floor Mr Chips Appliances 11 10-20-2012 08:23 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Whirlpool Duet front loading washer drain pump Jrr1099 Appliances 1 04-08-2009 01:57 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
