Old 06-18-2007, 02:55 PM   #1
Frog in the toilet
What's he doing in the toilet?
The backstroke!
All joking aside, after hearing a frog in our plumbing for a few weeks it appeared in our upstairs toilet one evening. I removed it to our backyard a week ago. And now yesterday we are hearing another frog in the plumbing. The sound appears to be coming from the vent/drain stack behind the vanity/sinks in our upstairs bathroom.
So they got in through the vent or the sewer drain somehow. I'm guessing the vent, but I'm not sure how they got in there... We have tall trees in the yard, but none overhang the house in that area. Perhaps one frog got in and had some tadpoles?
Anyone have any experience with this or any ideas on how to "flush out" the vents->sewer? Can I take a hose onto the roof and put water down the vent? Is there anything I can put down the drain that would euthanize the frogs or encourage them "go with the flow" out of the house?
Finding frogs in the toilet is not helpful with potty-training my kids!
Thanks for any help or suggestions,
-flamtap
flamtap is offline   Reply With Quote
Old 06-18-2007, 03:46 PM   #2
Frog in the toilet
My question goes How did you remove it from where a week ago... it must be a tough task... no kidding... sitting on the toilet becomes a really brave job now...
for prevent another one goes in... try mesh the vent on the roof as the first shot... I suppose that is a dangerous job though consider the height...
KUIPORNG is offline   Reply With Quote
Old 06-18-2007, 03:55 PM   #3
Frog in the toilet
It was easy to scoop him (or her?) out of the toilet. Yes, it is a steep 2nd story roof so I am not eager to get up there... but that is worth trying.
Old 06-18-2007, 05:27 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Frog in the toilet
My guess is that the frogs have gotten in through the sewer line rather than down the roof vent stack, but it doesn't really matter, unless you want to put mesh over the stack.
In any case, you can flush them out with a garden hose down the stack driectly into the sewer, and they can escape from there.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-18-2007, 06:40 PM   #5
Home Improvement Guy
ron schenker's Avatar
Frog in the toilet
I'll bet you a bird was flying overhead with the frog in his beak and accidentally dropped it down the stack
Bye Bye lunch
ron schenker is offline   Reply With Quote
Old 06-23-2007, 06:10 PM   #6
That one Guy's Avatar
Frog in the toilet
Is there an open clean out outside?
I was called out to a steel plant out with a plugged sink in the bathroom, after running out about 15' of 3/8" cable I hit something solid.
I pulled back to see what was on my cable and found a mouse/mole looking thing!
It was torn in half and guts everywhere. The smell was awful and getting it off my cable was worse. I took pictures on my phone and emailed them to the dispatcher. Suprise Suprise!
That one Guy is offline   Reply With Quote
Old 06-23-2007, 06:29 PM   #7
Journeyman Plumber
Ron The Plumber's Avatar
Frog in the toilet
Ask the little ones, maybe they put them in there, you just never know.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-23-2007, 07:51 PM   #8
Union HVAC Tech.
Frog in the toilet
I would bet you have a cleanout with a missing cap in the shrubbery outside your house. I have also pulled out rodents and small mammals from sewer lines in the winter months years back as a helper. I can't even remember how many times I have pulled birds and squirrel nests out of roof stacks. I was thinking dropped by a bird but not a second one the same way.
bigMikeB is offline   Reply With Quote
Old 06-23-2007, 07:53 PM   #9
Union HVAC Tech.
Frog in the toilet
Secondly you might have a house with a house trap that has a capped vent line just outside the basement wall that has come off.
Old 06-24-2007, 07:33 AM   #10
747
registered
747's Avatar
Frog in the toilet
i think so to. Check main sewer clean out riser. Make sure the threaded cap is on. Mine is located about 6 feet off of the house in the yard.
747 is offline   Reply With Quote
More On This Topic
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
How to Unclog a Toilet
How to Unclog a Toilet by Expert Village
We have a toilet that's not flushing, or not flushing very well. What we want to find out is, is the problem in the toilet drain, or is the problem in the toilet tank delivering the water to the bowl? So what we do, we have the patented Gilbert's... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
