Frig Water Supply Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2011, 07:46 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
frig water supply line
We bought a new frig with a water dispenser and ice. The guy at Sears said to get a saddle valve kit from a plumbing supply store and do it my self. I'm a little wary on using a saddle valve
any suggestions???
Should I just get my plumber to do it for $100
Barry
Barry J is offline   Reply With Quote
Old 07-02-2011, 08:04 AM   #2
the Musigician
DangerMouse's Avatar
If you're uncomfortable doing it, $100.00 ain't bad.
DM
Old 07-02-2011, 08:07 AM   #3
Rewards Points: 340
I have used a saddle valve, but most people don't like them, because if they leak, now you have a hole in the pipe.
Have you coincided a Tee valve or fitting that would connect to your existing cold water shutoff ?
http://www.homedepot.com/webapp/wcs/...atalogId=10053
tribe_fan is offline   Reply With Quote
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
Leak from water supply line & inlet elbow in newly installed dishwasher jrinco11 Plumbing 7 09-22-2010 07:39 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
