French Drain Help 11 - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2010, 08:10 PM   #1
Rewards Points: 530
French drain help 11
I didn't want to hijack the first thread on this subject so, how far from house and what if a gas line is going through the gravel near the top? I say near the top, I don't know how deep the utility company buried the flexible line when they replaced the old line a few years ago.
Old 05-03-2010, 10:20 PM   #2
Rewards Points: 1,418
The French drain is laid next to the foundation footing. It needs to be below the basement floor level. But you may not dig below the bottom of the footing of an existing house because that may cause the soil under the footing to slip.
You can dig leaving the gas pipe suspended in mid-air. Just be careful not to hit or bend the gas pipe either when digging or when refilling.
French Drain Suggestions doublejz Landscaping & Lawn Care 10 04-29-2010 04:19 PM
Do I need to waterproof my basement if I already have a french drain? buratti Building & Construction 4 03-20-2010 04:32 PM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 10:37 AM
French Drain Solution? Any Help Would Be Great! gregt848 General DIY Discussions 2 08-01-2008 10:16 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
