French Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-14-2011, 09:31 PM   #1
French drain
How hard is it to install a French drain and sump pump
Dammon215 is offline   Reply With Quote
Old 08-15-2011, 06:23 AM   #2
NOT easy!!! It requires cutting part of the floor out, and installing the drains. Best left to a pro., or read up on the subject before attempting it.
Old 08-15-2011, 10:44 AM   #3
Rewards Points: 1,492
You need to cut a trench all the way around the perimeter of the basement, to the depth of the foundation footings. Do not carve the earth below the bottom surface of the footings, although if you dig the trench 12 inches in from the footing side (probably 16 inches in from the foundation wall) then you can dig four inches further down which may assist in sloping the perforated drain pipes better.
AllanJ is online now   Reply With Quote
what to do with the french drain behind a retaining wall MLMIB Building & Construction 4 04-08-2011 07:52 AM
French Drain to Drain Roof DIYTKINNEY Landscaping & Lawn Care 2 11-08-2010 04:53 PM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 10:55 AM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 09:37 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
